/ Blog / Epoxy vs. Polyester Powder Coat
August 31, 2026 Uncategorised
powder-coated parts
One of our most popular finishes is powder coating. It’s pretty much the industry standard for painting metal because it gives you a really high-quality, durable finish. You can use it for cosmetic reasons as well as for functional purposes, which is why it’s so popular.
While epoxy and polyester powder coatings are both durable, they’ve got some key differences when it comes to areas like UV resistance, corrosion protection, chemical resistance and long-term appearance. Understanding these differences will help you figure out which coating is the best fit for your specific project.
Epoxy Powder Coat
Let’s start with epoxy. When you cure epoxy powders, they create this really hard, dense film that sticks to metal incredibly well. Its biggest strengths are its resistance to chemicals and corrosion, and it’s super tough against impacts. Epoxy can handle solvents, acids, alkalis and abrasions well.
But, there’s a catch: sunlight. Epoxy has pretty poor UV resistance. So, if you leave an epoxy finish out in the sun, it’s going to start to chalk. The surface oxidizes and turns into this dull, powdery layer and the color will start to fade.
At first, this is just a cosmetic issue – the coating is still protecting the metal underneath. But it starts looking pretty bad, pretty fast. That’s why epoxy is almost always considered an interior-only finish, especially for any application where appearance matters.
powder coat samples with different colors
We stock a wide range of powder coat colors
On the other hand, you’ve got polyester powder coating. With polyester, you’re trading a little bit of that chemical resistance for fantastic weatherability. They hold up great against UV rays, so the color and gloss stay put. They also resist chalking and handle outdoor temperature changes and moisture really well.
This makes polyester your go-to for pretty much anything that goes outside.
Polyester powder coats are still mechanically tough and gives you good corrosion protection, just not quite on the same level as epoxy. But polyester powder coats generally have better flexibility and impact resistance.
Which One is Better for Your Project?
Epoxy is your best bet if the part is going to live indoors, or maybe inside an enclosure. You’ll also want to go with epoxy if you need the absolute best protection against chemicals and corrosion, or if you know it’s going to get knocked around and take a beating.
Polyester, meanwhile, is what you want for anything that’s going to be outside, exposed to sunlight and adverse weather.
It’s also the right choice when you want that color and gloss to last for a really long time. So, for most general-purpose stuff that needs a good, solid, all-around finish, polyester is the way to go.
Epoxy-Polyester Hybrid Powder Coats
We also stock epoxy-polyester hybrid powder coats. These blend both resins to capture much of epoxy’s chemical and corrosion resistance while improving overbake tolerance and finish quality.
But hybrids still chalk under UV, so they remain a finish for interior use. For really demanding indoor jobs, it is your best bet, so think of them as a refined epoxy rather than an outdoor alternative.
Stocked Powder Coat Colors
As of August 2026, we have 40 standard powder coat colors in stock, and we’re always adding new options in-house. So, make sure to keep an eye on the powder coat page on our website to see the latest collection.
