FREE WEBINAR | October 27: Learn how we accelerate your projects using HVMC™.
Aluminum Angle
Extrusions & Structural tolerances and specifications
Fabrication Tolerances for Dimensional Variance in Aluminum Angle and Machined Parts
Standard Tolerances For Structural Aluminum Angle
Aluminum angle
Stocked Aluminum Alloy (Angle)
Specified Thickness Alloy Tolerance
1" | 25.4mm TP304 ± 0.025" | 0.64mm
2" | 50.8mm TP304 ± 0.030" | 0.76mm
More Extrusions & Structural Tolerances
