FREE WEBINAR | October 27: Learn how we accelerate your projects using HVMC™.
Aluminum Bar Stock
Bar Stock (CNC Machining) tolerances and specifications
Fabrication Tolerances for Dimensional Variance in Aluminum Bar Stock and Machined Parts
Stocked Aluminum FLAT Bar Stock
Specified Thickness Alloy Tolerance
1/2" x 3/4" | 12.70mm x 19.05mm 6061-T6 ± 0.024" | 0.61mm
1/2" x 1" | 12.70mm x 25.4mm 6061-T6 ± 0.012" | 0.30mm
1/2" x 2" | 12.70mm x 50.80mm 6061-T6 ± 0.024" | 0.61mm
1/2" x 4" | 12.70mm x 101.60mm 6061-T6 ± 0.034" | 0.86mm
3/4" x 3/4" | 19.05mm x 19.05mm 6061-T6 ± 0.010" | 0.25mm
3/4" x 2" | 19.05mm x 50.80mm 6061-T6 ± 0.024" | 0.61mm
3/4" x 4" | 19.05mm x 101.60mm 6061-T6 ± 0.034" | 0.86mm
1-1/2" x 2" | 38.10mm x 50.80mm 6061-T6 ± 0.024" | 0.61mm
1-1/2" x 3" | 38.10mm x 76.20mm 6061-T6 ± 0.024" | 0.61mm
1" x 2" | 25.40mm x 50.80mm 6061-T6511 ± 0.024" | 0.61mm
1" x 4" | 25.40mm x 101.60mm 6061-T6511 ± 0.034" | 0.86mm
1" x 6" | 25.40mm x 152.40mm 6061-T6 ± 0.044" | 1.18mm
2" x 2" | 50.80mm x 50.80mm 6061-T6511 ± 0.024" | 0.61mm
2" x 3" | 50.80mm x 76.20mm 6061-T6511 ± 0.024" | 0.61mm
3" x 3" | 76.20mm x 76.20mm 6061-T6 ± 0.034" | 0.86mm
Stocked Aluminum ROUND Bar Stock
1" | 25.4mm 6061-T6 ± 0.012" | 0.30mm
1.5" | 38.1mm 6061-T6 ± 0.014" | 0.36mm
2" | 50.8mm 6061-T6 ± 0.024" | 0.61mm
2.5" | 63.5mm 6061-T6 ± 0.024" | 0.61mm
3" | 76.2mm 6061-T6 ± 0.024" | 0.61mm
4" | 101.6mm 6061-T6 ± 0.034" | 0.86mm
6" | 152.4mm 6061-T6 ± 0.044" | 1.18mm
More Bar Stock (CNC Machining) Tolerances
