FREE WEBINAR | October 27: Learn how we accelerate your projects using HVMC™.
Aluminum Extrusion
Extrusions & Structural tolerances and specifications
Standard Tolerances For Aluminum Extrusion
1U Extrusion
2U Extrusion
Stocked Aluminum 6063 Extrusion
Height Tolerance (Height) Tolerance (Width)
1U (Height: 1.72" | 43.688 mm) ± 0.014" | 0.36mm ± 0.010" | 0.25mm
2U (Height: 3.47" | 88.138 mm) ± 0.024" | 0.61mm ± 0.010" | 0.25mm
More Extrusions & Structural Tolerances
