Cold Rolled Steel Bar Stock
Bar Stock (CNC Machining) tolerances and specifications
Fabrication Tolerances for Dimensional Variance in Steel Bar Stock and Machined Parts
Standard Tolerances For Cold Rolled Steel Bar Stock
Hot Rolled Steel
Stocked Cold Rolled Steel ROUND Bar Stock
Specified Thickness Alloy Tolerance
1" | 25.4mm Grade 1018 ± 0.002" | 0.051mm
2" | 50.8mm Grade 1018 ± 0.003" | 0.08mm
More Bar Stock (CNC Machining) Tolerances
