FREE WEBINAR | October 27: Learn how we accelerate your projects using HVMC™.
Cold Rolled Steel
Sheet Metal tolerances and specifications
Sheet Metal Thickness
Standard Tolerances For Cold Rolled Steel
Cold Rolled Steel Specified Thickness Tolerance
11 Gauge 0.120" | 3.05 mm ± 0.006" | 0.15mm
12 Gauge 0.105" | 2.67 mm ± 0.006" | 0.15mm
13 Gauge 0.090" | 2.29 mm ± 0.005" | 0.13mm
14 Gauge 0.075" | 1.91 mm ± 0.005" | 0.13mm
16 Gauge 0.060" | 1.52 mm ± 0.005" | 0.13mm
18 Gauge 0.048" | 1.22 mm ± 0.004" | 0.10mm
20 Gauge 0.036" | 0.91 mm ± 0.003" | 0.08mm
22 Gauge 0.030" | 0.76 mm ± 0.003" | 0.08mm
