FREE WEBINAR | October 27: Learn how we accelerate your projects using HVMC™.
Self-Clinching Fasteners
Fasteners tolerances and specifications
Self-Clinching Fasteners Tolerances
Pem Position
Self-clinching fasteners, often called PEMs, after Penn Engineering & Manufacturing Corp., are threaded nuts, studs, or standoffs that are mechanically pressed into sheet metal to create strong, solid fastening points.
Protocase determines the correct nominal hole size to ensure each self-clinching fastener is securely installed.
From your perspective as a designer, the positional tolerance for self-clinching fastener placement is simply our "hole" position tolerance, which is typically ± 0.005" (0.13 mm).
When designing, you may also need to know what to expect for the physical dimensions of the fasteners themselves.
Self-clinching fasteners must follow minimum bend requirements – see Minimum Bend page here.
For more information about PEM fasteners and their tolerances, visit the PEM website.
PEM Tolerance
Dimensional tolerance of pems ± 0.005" | 0.13mm
More Fasteners Tolerances
