Tolerances represent the allowable variation in dimensions for a part or assembly. They ensure that individual features fit together correctly during assembly and function as intended. However, when multiple tolerances apply to an assembly, these variations can “stack” together, potentially leading to dimension-related issues.
To illustrate this, imagine a sheet metal assembly consisting of five panels aligned side by side, each designed to be 0.787” (20mm) wide with a tolerance of +/- 0.010” (±0.254mm). Due to the tolerance for each panel, the total width may actually range from 3.877” (98.5mm) to 3.996” (101.5mm). This is the result of tolerance stacking.
Due to this reason, stacked tolerances can significantly impact the manufacturability and performance of sheet metal parts.
When tolerances stack beyond acceptable limits, a bunch of problems may arise such as: parts not fitting together due to improper alignment, cutouts and bends can become slightly misaligned during assembly, both causing delays in manufacturing with unnecessary iterations and therefore an increase of cost.
Before getting into design advice, it’s important to understand which key factors contribute to stacked tolerances in sheet metal.
Complex Designs
Material Properties & Behavior
Now that you understand the importance of a stacked tolerance, let’s look at some tips that will help you design smarter:
Simplify Your Design
Establish Functional Tolerance Zones
To put this design advice into perspective, consider a sheet metal enclosure with multiple tabs for mounting electronic components inside. If each tab’s position tolerance is +/- 0.010” (0.254mm) the accumulative deviation may lead to misaligned components.
To address this, you could:
To conclude, stacked tolerances may be a small detail, but they can cause big problems if overlooked for complicated designs. For engineers designing with sheet metal, understanding and addressing tolerance stacking is essential for creating manufacturable and reliable products.
