Stainless Steel
Sheet Metal tolerances and specifications
Standard Tolerances For Stainless Steel
304 Stainless Steel (A240 TP304 2B)
Stainless Steel Specified Thickness Tolerance
11 Gauge 0.120" | 3.05 mm ± 0.005" | 0.13mm
12 Gauge 0.109” | 2.78mm ± 0.009" | 0.23mm
14 Gauge 0.078” | 1.98mm ± 0.007" | 0.18mm
16 Gauge 0.063” | 1.59mm ± 0.006" | 0.15mm
18 Gauge 0.050” | 1.27mm ± 0.005" | 0.13mm
20 Gauge 0.038” | 0.95mm ± 0.004" | 0.10mm
22 Gauge 0.031" | 0.79 mm ± 0.004" | 0.10mm
24 Gauge 0.025" | 0.64 mm ± 0.003" | 0.08mm
