Aluminum parts, panels and enclosures that have been manufactured in our own facilities
Aluminum parts that have been fabricated or machined elsewhere, so long as they meet our dimension constraints.
We are able to process aluminum parts with maximum dimensions of 43.5" x 34" x 30" (1104.9mm x 863.6mm x 762mm).
Protocase-Fabricated Parts
As the coating is done in-house, chemical conversion coating can be applied to enclosures and parts within 1 day. This means we can offer fully fabricated and finished sheet metal enclosures and components with chemical conversion coating, in as little as 3-4 days.
Customer-Supplied Parts
Protocase can apply chemical conversion coating to customer-supplied parts in as little as 3-4 days after receipt of parts.
We do not recommend applying chemical conversion coating to unfinished aluminum parts. Bare-metal aluminum parts with No Finish will have surface scratches, swirl marks and blemishes. The application of chemical conversion coating will not mask or hide the blemishes of No Finish parts.
For the best end result, we recommend choosing Grained Finish or Vibratory Finish for your aluminum parts before they are treated with chemical conversion coating.
If you require your chem-filmed parts to be powder coated in certain areas, we can do that. Once we apply the chemical conversion coating, the part will be masked in the required areas before it is powder coated.
Chem Film Aluminum with Grained Finish
Chem Film Aluminum with No Finish
Chem Film Aluminum with Vibratory Finish
Aluminum parts with chemical conversion coating can have graphics in the form of direct digital printing and silkscreening. For more information about your finishing options in combination with chem film conversion coating, please contact us.
Protocase uses Chemeon TCP-HF®. The coating subtly changes the appearance of the surface, which exhibits nearly clear iridescence, with a subtle gold to violet tint.
Chemeon TCP-HF® is an environmentally friendly trivalent chromium formulation, free of toxic and dangerous hexavalent chromium. Chemeon TCP-HF® conforms to a wide variety of environmental and workplace safety regulations, such as RoHS, WEEE, ELV, REACH and the OSHA PEL.
Protocase qualifies its process to pass the requirements of MIL-DTL-5541F Type 2 Class 1A & 3, and -81706B.
Chemeon TCP-HF® is a proprietary chemistry developed by Pratt and Whitney Aircraft®, one of the world's leaders in the manufacturing of civil and military aircraft engines and as such, this technologically advanced product was tested against the most rigorous standards used in high performance chromate conversion for aerospace applications.
*Protocase meets the requirements of MIL-DTL-5541F and MIL-DTL-81706B.
