Aluminum
Stainless Steel
Copper
Copper Bus Bar With Media Blasting
Media Blasted Panel With Different Laser Marking Types
Two Copper Bus Bar Styles With Media Blasting
CNC Machined Enclosure With Media Blasting
CNC Machined Enclosure with Media Blasting
Permanent Markings: Engrave and Fill, Laser Marking, Rubber Stamping
Graphics: Digital Print, Silkscreen
Maximum part size: 6" x 6" x 6" (152.4mm x 152.4mm x 152.4mm).
Minimum part size: Part must have at least one dimension that exceeds 2" (50.8mm).
Large, thin sheet metal should be avoided in order to avoid warpage.
We recommend handling with gloves in order to avoid staining or smudging the parts.
As media blasting is a manual process, results may vary in terms of uniformity, especially when anodizing will be applied to your media-blasted part.
