Media Blasting
Your part is deburred and cleaned, then sprayed with a steady stream of tiny glass beads via compressed air. The end result is a smooth, bright finish that’s flat and non directional.
Media Blasting is excellent for machined parts, and can be done on sheet metal parts.
Materials
We can apply media blasting on the following materials:
• Aluminum
• Stainless Steel
• Copper
Sheet Metal Samples:
Machined Samples:
Additional Finishes & Marking:
- • Permanent Markings: Engrave and Fill, Laser Marking, Rubber Stamping
- • Graphics: Digital Print, Silkscreen
Constraints
- • Maximum part size: 6” x 6”x 6” (152.4mm x 152.4mm x 152.4mm).
- • Minimum part size: Part must have at least one dimension that exceeds 2” (50.8mm).
- • Large, thin sheet metal should be avoided in order to avoid warpage.
Notes
- • We recommend handling with gloves in order to avoid staining or smudging the parts.
- • As media blasting is a manual process, results may vary in terms of uniformity, especially when anodizing will be applied to your media-blasted part.
