Vibratory Finish
Your parts are placed in a vibratory machine with an abrasive medium.
This smooths out the surface, adds a random pattern and rounds off the edges nicely, resulting in a finish that looks a lot like frosted glass, typically much smoother than a grained finish.
It’s a great option if you’re after a random, non-directional bare metal finish.
Plus, vibratory finish is a great choice for machined parts.
Materials
We can apply vibratory finish on the following materials:
• Steel
• Stainless Steel
• Galvanneal
• Aluminum
Additional Finishes & Marking:
- • Permanent Markings: Laser Marking, Engrave and Fill, Machined Engraving, Dot Peening, Rubber Stamping
- • Graphics: Digital Print, Silkscreen
Constraints
- • Maximum part size: 10"L x 10"W x 10"H
- • Minimum part size: Cross-sectional dimension of at least 1" (25.4 mm) and a length of at least 3" (76.2 mm)
- • Not available in copper
