Stop waiting weeks for custom MRO parts.
Meet Protocase.
Powered by High-Velocity Mass Customization (HVMC™).
When equipment fails, getting it back up and running is the priority. But sourcing replacement parts is rarely simple. When OEM components reach end of life or carry unacceptable lead times, custom parts become the path forward. Traditionally, job shops have been the default for custom parts — but backlog-driven schedules and unpredictable timelines often mean waiting weeks. Protoccase puts you back in control. With our High-Velocity Mass Customization (HVMC™) model for MRO, we manufacture custom brackets, enclosures, gaskets, and more in as little as 2–3 days — either from your drawings or through our expert reverse engineering. Restore operations faster. Reduce downtime. Stay in control.
Our nominal 2-3 day lead time to keep your project moving fast while eliminating latencies.
Cost-effective manufacturing with a lead time of 3 weeks, perfect for budget-conscious projects.
We're happy to provide dedicated, around-the-clock support to select customers. Contact us for more details.
Stop juggling multiple vendors for different fabrication needs. With our HVMC model, we offer true custom capability under one roof, eliminating handoffs and delays.
Precision components built fast to replace worn or broken mechanisms.
Enclosures, brackets and panels tailored to fit your specific facility requirements.
High-quality components, copper or aluminum, for your electrical infrastructure needs.
Rapid interim solutions to get you through an emergency while the final part is fabricated.
Mechanical seals that fill the space between two or more mating surfaces.
Designed to cover rotating or hazardous areas of operating machinery.
Critical machinery failure? Contact us for expedited support. We understand that downtime costs thousands per hour.
Call Now
1-877-260-8055Send An Email
mro@protocase.comDon't have the original technical drawings? No problem.
Send us the worn, broken, or obsolete part. We use 3D scanning and engineering expertise to re-create it to original (or improved) specifications.
Don't replace expensive machinery just because a single component failed. We help you fix known failure modes and improve durability.
We offer tools to simplify the request-to-part process, allowing your team to focus on maintaining uptime instead of getting stuck in design and ordering latencies.
Every custom part you order becomes a saved asset in My Account. When you need a replacement, your purchaser can simply press a button to release a reorder. No re-quoting, no re-explaining, and zero purchasing chaos during an emergency.
Use My Account
Your maintenance staff can use our software to design simple brackets, plates, and enclosures in minutes (no expertise required!). This reduces back-and-forth communication and speeds up production.
Launch Protocase DesignerYes. Our entire facility is optimized for velocity. 2-3 days is our standard lead time for custom sheet metal and machined parts, not an expedited exception.
That is not a problem. We specialize in reverse engineering. You can send us the physical part, and we will 3D scan and engineer a replacement for you.
Absolutely. We understand that downtime is costly. Contact us immediately for emergency support, and we will work to get your critical parts fabricated as fast as physically possible.
