Engineers and designers often choose a powder coat finish for their custom enclosures and parts because it provides a bright, vibrant and professional look. But what if you don’t need to have your enclosures or parts painted but still need them to be aesthetically pleasing?
At Protocase, we offer bare-metal finishes including a grained finish that applies a linear grain onto the surface, producing a sleek, minimalist look.
Grain direction refers to the orientation of the natural crystalline structure formed during the rolling process of sheet metal. It significantly affects the material’s mechanical properties, including strength, aesthetics, durability and susceptibility to cracking when bent and/or fastened together.
We can also apply an aesthetic grained finish on top of the sheet, which can amplify some of these properties.
There are multiple reasons the direction of the linear grain matters:
When designing a part or enclosure with a grained finish, there are a few best practices to consider. Here are a few key points to remember:
It is standard practice that critical bends should be made across the grain to improve durability. Depending on your design requirements, bending perpendicular to the grain may be unavoidable. In this case, use a larger bend radius to reduce the stress concentration.
At the very beginning, you will need to determine the material for your sheet metal design. Designers need to understand that some materials are more sensitive to grain direction, so consider higher-grade options for critical applications.
Stainless steel is a go-to material for grained finishes due to its ability to hold a consistent grain pattern and has superior strength and long-lasting durability.
If you are looking for a material that is perfect for a grained finish but need a lighter weight, then aluminum would be the next best choice.
Finally, cold rolled steel also has a smooth surface that is ideal for grain finishing and has excellent compatibility with protective coatings.
When creating sheet metal flat patterns, specify grain direction using annotations to ensure proper alignment between the design files and manufacturing. Thorough communication within your design and with our Engineering & Design Services team will reduce the risk of errors and speed up the design to manufacturing process.
Since most of you will be using SolidWorks to design your next project, here’s a simple step by step on how to define grain direction inside the software:
Still have questions about grain direction? Please get in touch by filling out the form on our Contact Us page. We’ll be glad to help you accelerate your project velocity!
