Aluminum Angle
Extrusions & Structural tolerances and specifications
Fabrication Tolerances for Dimensional Variance in Aluminum Angle and Machined Parts
Standard Tolerances For Structural Aluminum Angle
Stocked Aluminum Alloy (Angle)
Specified Thickness Alloy Tolerance
1" | 25.4mm TP304 ± 0.025" | 0.64mm
2" | 50.8mm TP304 ± 0.030" | 0.76mm
More Extrusions & Structural Tolerances
