Stainless Steel Bar Stock
Bar Stock (CNC Machining) tolerances and specifications
Fabrication Tolerances for Dimensional Variance in Stainless Steel Bar Stock and Machined Parts
Standard Tolerances For Stainless Steel Bar Stock
Stocked Stainless Steel (Rectangular Bar Stock)
Size Alloy ASTM Standard Thickness Tolerance
(1" x 1" | 25.4mm x 25.4mm) 304 ± 0.009"
(1" x 2" | 25.4mm x 50.8mm) 304 ± 0.015"
(2" x 2" | 50.8mm x 50.8mm) 304 ± 0.016"
(3" X 3" | 76.2mm x 76.2mm) 304 ± 0.047"
Stocked Stainless Steel Alloy (Round Bar Stock)
Specified Thickness Alloy Tolerance
1" | 25.4mm TP304 ± 0.025" | 0.06mm
2" | 50.8mm TP304 ± 0.003" | 0.08mm
More Bar Stock (CNC Machining) Tolerances
