Standard Tolerances For Cold Rolled Steel
Usually, choosing material thickness is one of the first steps a designer takes when starting a project. We work with nominal thicknesses, so it's important to know the thickness tolerance on the material you chose, in order to know if the final product will be suitable for your application. It's also important when working with sheet metal that you factor in finish tolerances. For example, if you add a finish such as powdercoat, you add more thickness - this should be factored into your design at the beginning.
| Cold Rolled Steel | Specified Thickness | Tolerance | |
| 11 Gauge | 0.120" | 3.05 mm | ± 0.006" | 0.15mm | |
| 12 Gauge | 0.105" | 2.67 mm | ± 0.006" | 0.15mm | |
| 13 Gauge | 0.090" | 2.29 mm | ± 0.005" | 0.13mm | |
| 14 Gauge | 0.075" | 1.91 mm | ± 0.005" | 0.13mm | |
| 16 Gauge | 0.060" | 1.52 mm | ± 0.005" | 0.13mm | |
| 18 Gauge | 0.048" | 1.22 mm | ± 0.004" | 0.10mm | |
| 20 Gauge | 0.036" | 0.91 mm | ± 0.003" | 0.08mm | |
| 22 Gauge | 0.030" | 0.76 mm | ± 0.003" | 0.08mm |
