Rubber Stamping
  • Permanent labeling using number and/or letter combinations.
  • Especially useful for serialization and traceability.
  • Done by creating letter and number combinations using stamps, then applying directly onto an enclosure or part using permanent ink.
Rubber Stamping Examples
Specifications
Specification Details
Ink Colors Black, White
Character Height Approximately 0.150" (3.81mm) tall
Stamp Body Size 0.157" (3.99mm) wide × 0.279" (7.09mm) tall
Information Required When Placing an Order
When placing an order wherein you require rubber stamping, please ensure you provide us with all of the information we need:
  • Characters to be stamped
  • Specific location of the text (in particular, the location of the first character)
MIL-STD-130 (Table II)
Rubber Stamping is a permanent part marking method which is recommended for applications requiring MIL-STD-130 (Table II).
