Silkscreen vs. Direct Digital Printing
Protocase offers two graphics methods for your custom enclosures and parts. Both are included in our standard 2-3 day turnaround with no minimum order. Here's how they compare to help you choose the right option.
Silkscreening
A traditional printing method where ink is pushed through a mesh screen onto the surface. Produces thick, durable ink deposits perfect for logos, text, and solid-color branding.
UV-cured inkjet printing applied directly onto the metal surface. Supports full CMYK color with photorealistic quality, gradients, and complex graphics.
Side-by-Side Comparison
Feature Silkscreen Digital Printing
Color Options Limited to spot colors (typically 1-3 colors per side) Full CMYK color — unlimited colors, gradients, and photographic images
Image Quality Sharp, crisp lines and text. Best for solid colors and logos Photorealistic quality. Supports complex graphics and photographs
Durability Excellent durability with thick ink deposit. Highly scratch-resistant Very good durability under normal use. UV-resistant clear coat available
Setup Cost Higher setup cost per color (screen creation). Economical at higher volumes No setup cost per design. Cost-effective for low quantities and prototypes
Turnaround Included in standard 2-3 day turnaround Included in standard 2-3 day turnaround
Best For Logos, part numbers, labels, and solid-color branding Full-color graphics, photos, gradients, and complex designs
Color Matching Pantone color matching available for precise brand colors CMYK process — close but not exact Pantone matching
Minimum Order No minimum — available on single parts No minimum — available on single parts
Quick Decision Guide
Choose Silkscreen if you need:
  • Maximum scratch resistance
  • Pantone color matching
  • Thick, tactile ink feel
  • Simple logos and text
Choose Digital if you need:
  • Full-color or photographic images
  • Gradients and complex artwork
  • Low-quantity or prototype runs
  • Frequent design changes
Ready to add graphics to your enclosure?
Both silkscreening and digital printing are available with no minimum order and ship in 2-3 business days.
