Tin Plating
  • We offer tin plating for copper.
  • It is applied to copper to improve corrosion resistance, electrical conductivity and solderability.
  • The finish color ranges from bright to a dark, matte gray. This is dependent upon material thickness, age of tin solution and dipping time.
  • Please be advised that additional lead time is required as the process is completed off-site via trusted third-party suppliers.
  • For large quantities, please contact your account manager to discuss your order.
Bright Electroless Tin Plating for Copper
What is it?
The Tin Plating process is a simple immersion technique that deposits pure tin onto copper.
Bright Electroless Tin is a well-developed formulation based upon the reduction characteristics of chelated tin in the divalent state. Under proper conditions, reduction to pure tin occurs readily. A grain-refining agent, free of phosphorus, is present, as well as an activator and buffers for pH control.
The deposited tin has many favorable properties:
  • Fine-grain tin structure
  • Good chemical resistance
  • Excellent adhesion
  • Highly resistant to corrosion, even under exposure to humidity and salt-spray
  • Highly solderable
Regulatory Compliance
If you require ROHS and REACH-compliancy, please contact us.
Size Restrictions
Contact us at info@protocase.com to discuss your project.
