Dot Peening
Protocase Tech Tip Video
Permanent markings are dot peened onto each part after it is cut, but before it is bent. The identification codes are generally marked on flat areas of an enclosure, however they may be put over a bend line as well (although this will result in some distortion of the text).
Dot peening can be used on aluminum parts with or without a powdercoat finish as the depth of the peening is sufficient to show through the powdercoat, and both allow for good visibility.
When it comes to powdercoated steels, dot peening should be done after powdercoat to ensure text is visible.
Dot Peening Examples by font:
Dot Peening by Protocase
Dot Peening under powdercoat:
Marking Area:
The maximum area of each marking window for text is X=1.875" (48mm) (x) Y=1" (25.4mm)
Permanant Mark Finish: Marking Area
Please Note: The text CANNOT be rotated to create a window that is X=1" (25.4mm) x Y=1.875" (48mm). However, customers can request smaller X and Y values for their text window - please inform our sales team if this is the case.
Tolerances:
Positional tolerance of text is +/-0.125" (3.18mm) on x and y. Tighter tolerances are possible, but you should contact our technical support should this be necessary.
Thin Material:
When requesting Dot Peen Marking on aluminum material thinner than 0.051" (1.30mm) , ghosting or witness marks may appear on the reverse side of the print area. However, this is not an issue with other material (ie: Cold Rolled and Stainless Steel) above 0.048" (1.22mm)
Serialization:
We have the capability to add incremental serial numbers as part of a marking.
Information required when placing an order:
When placing an order with dot peening required, ensure you provide us with:
  1. Characters to be "peened"
  2. Character Size
  3. Specific Location of the Text; in particular, the location of the first character.
Font Capabilities:
Our system contains 5 different fonts with 2 dot pitches and variable text heights. We currently offer five font types: Varidot (default font), Varidot OCR, 5x7 Dot, 7x9 Dot, and 5x9 Dot OCR. Our standard text heights are between 0.075" (1.86mm) to 0.150" (3.52mm). The following are maximum lines and characters varying by our standard text heights:
0.150" (3.52mm)
  • 5 Lines of Text
  • 14 Characters / Line
  • 7x9 dot = 13 characters / Line
  • 70 Characters / Window
0.125" (3.10mm)
  • 6 Lines of Text
  • 16 Characters / Line
  • 96 Characters / Window
0.100" (2.48mm)
  • 8 Lines of Text
  • 20 Characters / Line
  • 160 Characters / Window
0.075" (1.86mm)
  • 8 Lines of Text
  • 26 Characters / Line
  • 7x9 dot = 25 Characters / Line
  • 208 Characters / Window
Lower case text is available but may be obscured under powdercoat; testing will be required.
Please contact our sales team if you require non-standard text heights, as testing will be required.
MIL-STD-130 (Table II)
Dot Peening is a permanent part marking method which is recommended for applications requiring MIL-STD-130 (Table II).
